I found one more page not working after upgrading from 1.3.02 to 1.3.5.
advanced search
Although i dont make use os the advanced search page, (no sideboxex etc) it still shows up at the sitemap.
Not a very big problem, people may use it still, but it returns an error with the 1.3.5 version of init_add_crumbs.php installed.
rolled back to the 1.3.0.2 version of this file and then the results where processed correctly again.
the actual errors reads with the 1.3.5 version:
Warning: constant(): Couldn't find constant in myroot/includes/init_includes/init_add_crumbs.php on line 45
1064 You have an error in your SQL syntax near 'from where manufacturers_id = 0' at line 2
in:
[select from where manufacturers_id = 0]
in the init_add_crumbs.php file itself, line 45 showes:
from " . constant($get_terms->fields['get_term_table']) . "
