Try adding height:1% to the centerBoxWrapper class. This forces IE (6 and 7) to properly calculate the dimensions of the box before wrapping the border around it.
Is this the IE7 problem you talking about???
Hi there. I have used the IE stylesheet override, and it works wonderfully for most of my site. However in some cases I have separate stylesheets for certain product pages (named p_180.css, p_211.css, etc). How can I create an IE only stylesheet for these particular pages?
Any help at all would be greatly appreciated!
Hi I have a Question, I am having a big problem. I just notice in Intenet Explorer, IE7 reported an error and would not load any of the product pages. This error only appears when a product page is loaded after clicking on a product name or image from the product listing page. The error message reads as follows and appears in a warning message dialog box. After clicking on the ok button the usual 'This page cannot be displayed message' is shown.
Intenet Explorer cannot open the Internet site
www.thegoodshepherdstore.com/...oducts_id=1018
Operation aborted
Do you have any clue of what this could be. Thank you very much.
Just started to do this for some strange reason. Works fine in firefox
Is your site Upgraded to the current version 1.5.4 Yet?
zencart-upgrades-website-installation
This may sound like a stupid question, but where do I go or what files do I fix to correct these 34 Errors.
http://validator.w3.org/check?verbos...rdstore.com%2F
Thank you very much
countrycharm, you need some serious recoding done to your Template.
You may find that as the errors are corrected, previous errors/problems will magically disappear. That's the beauty of using Valid code.
If not sure how to correct the errors you will need to hire someone or go back to whomever you got the Template from. Doesn't look like a TemplateMonster template but sure is acting like one.
The template looks to me to be Cherry Zen which was extensively tested by its author, Jade.
It comes with just one minor validation error, the first one where the validator doesn't like "search" as an input type. This has no effect on any browser other than Safari which needs it in order to display the (ironically) Safari-style search fields.
The rest of the errors have been introduced by countrycharm, so fixing them should be a matter of going back over the changes that you have made to identify those which produce invalid code.
An approach of this is to start with the second error, find it's source and then you will certainly benefit from the cascade effect to which Website Rob referred above, with a number of problems disappearing at once.
kuroi, Website Rob, thank you very much for your reply and the direction to go in. (1)First of all let give a update. I fix the first problem with Intenet Explorer or maybe not fixed it but I did away with zen_lightbox_1.4. For some reason Intenet Explorer would not work on my site with this mod installed.
(2) I have correct these 33 Errors I had except for the 1 Kuroi was talking about that doesn't like "search" as an input type. Any way I just wanted to give an update and say thanks again.
