Thanks Dr. Byte, that works. Unfortunately, this still doesn't seem to help achieve my goal of offering coupons on an arbitrary set of products and updating via Easy Populate. That's because it appears that linked products are not supported by Easy Populate. (I may confirm that in the EP support thread).
In any case, I kind of like my solution which I added a few posts ago:Does this seem viable?However, I may have another approach that might work better for me. Optimally, these same products would also be the Featured Products. Unfortunately, Easy Populate doesn't support Featured Products and there doesn't seem to be a coupon restriction for Featured Products.
The solution requires treading in the land of MySQL, a place that I probably do not belong. After creating the coupon by normal means, I updated the zen_featured and zen_coupon_restrict tables to include the products. This seems to work, but I've only done a small amount of testing. Do you think that this will eventually be blown apart by landmines, or is this a workable solution?
