Jason,
the problem you are having is your Google Analytics code - it is in HTTP format
<script src="http://www.google-analytics.com/urchin.js" type="text/javascript">
</script>
_uacct = "UA-.......";
urchinTracker();
</script>
You should put a switch to where when its in SSL, it won't show it. The better option would be to use Google Analytics Integration mod by Andrew (a_berezin) - http://zen-cart.spb.ru/index.php?mai...=contributions
It has everything built in for you and will place it in the correct position as well. Yours is currently set up below the </html> tag.. which is a no-no
