Re: Images Won't Work (Any)
OK, here's what I did (this is a sum, for future readers)...
Originally I already had the folder /accessory-avenue created and tried different ways of installing the cart. First, I tried installing it via Fantastico into the folders accessory-avenue/store (if you have worked with Fantastico, you know that the ACTUAL folder to install the script into should not already exist, so I didn't create the /store folder prior to installing- I let Fantastico create it as it installed it.) However, the images didn't work, so I tried completely taking out the cart and starting back with just the folder /accessory-avenue. I still wanted it in the folder /store, so this time I created that folder and I manually installed the cart, which went well, but the images still wouldn't show up. So here's what I tried just to see if it would work and so far it appears to be... I decided that I would not use the folder of /store, but I still needed the cart installed into a subfolder of my main domain, so I completely deleted everything, even the /accessory-avenue folder I created to install everything into. I then went back to Fantactico (for ease of quickness, just to test this out) and told it to install the cart into the folder /accessory-avenue (remember that I deleted it, because Fantastico will create it for you during installation.) And voila! All the images work. Technically speaking, the cart was installed to http://celtickatt.com/accessory-avenue/ but I went back into GoDaddy and changed the information so that www.accessory-avenue.com will point to http://celtickatt.com/accessory-avenue/ and everything seems to work ok
I don't know if all of that made sense to people, and that may not cure the issue for other people (especially if their setup is not the same as mine) but if it is... that's what I did. And I'm PRAYING that don't have to mess with this issue anymore!
Thanks for all your replies schoolboy!
-Shannon
"You never really understand a person until you consider things from his point of view . . . until you climb into his skin and walk around in it." --Atticus
