Hi All,
I am having some issues setting up a multishop site.
I am using Gerome's Multishop module, which is still in beta.
Having said that I do not think that the errors are related to the module.
The errors can be seen below. If anyone has any hints or tips as to what these messages really mean I would appreciate any help I can get. The messages can be seen live at http://shop1.dcinet.com.au/catalog/
Warning: session_start(): Cannot send session cookie - headers already sent by (output started at /var/virtual/web/w0951/subdomain/shop1/catalog/includes/classes/category_tree.php:202) in /var/virtual/web/w0951/subdomain/shop1/catalog/includes/functions/sessions.php on line 108
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /var/virtual/web/w0951/subdomain/shop1/catalog/includes/classes/category_tree.php:202) in /var/virtual/web/w0951/subdomain/shop1/catalog/includes/functions/sessions.php on line 108
Warning: Cannot modify header information - headers already sent by (output started at /var/virtual/web/w0951/subdomain/shop1/catalog/includes/classes/category_tree.php:202) in /var/virtual/web/w0951/subdomain/shop1/catalog/includes/init_includes/overrides/init_templates.php on line 79
The method that I took to get to this stage is as follows:
1. upload zen to webserver using SmartFTP to run at http://www.scinet.com.au/catalog/
2. Installed zen using the installer scripts. everything went swimmingly, no errors and no problems.
3. Uploaded the red_passion template to play with.
4. applied the template to the "Primary" site, this is www.dcisnet.com.au/catalog/.
5. saw the difference, kinda liked it, set the template back to the classic default template.
6. installed the multishop module, which you can get from here at the moment: http://www.medea.co.uk/dev/multisite.zip. "BETA BETA BETA"
6. came across a couple of errors which Gerome helped me rectify. Back to happy happy happy.
7. copied the catalog directory back to my machine in a shop1 folder.
8. deleted the admin directory from the local copy of th catalog directory in the shop1 folder.
9. edited the /includes/configure.php file and made the following changes:
define('HTTP_SERVER', 'http://shop.dcinet.com.au');
define('HTTPS_SERVER', 'https://shop.dcinet.com.au');
define('DIR_WS_CATALOG', '/catalog/');
define('DIR_WS_HTTPS_CATALOG', '/catalog/');
define('DIR_FS_CATALOG', '/var/virtual/web/w0951/subdomain/shop1/catalog/');
define('DIR_FS_SQL_CACHE', '/var/virtual/web/w0951/subdomain/shop1/catalog/cache');
10. uploaded everything to http://shop1.dcinet.com.au/catalog/ and now I get Barfo.
As I said before any and all help is greatly appreciated. I am posting this in the hope that someone can give me a hand. I have already sent an email to Gerome, but as I do not think that this is related to his module I am posting it here too.
Kind regards,
David Buckley.
