Since a few weeks a cannot enter my admin pages anymore. When i enter my username and password i'll simply get redirected to the same login page. This same problem occurs also for my clients who try to login.
Some time before the problem occured i had to edit my configure.php file, see also: http://www.zen-cart.com/forum/showthread.php?t=59592
Searching the forum i found that the problem can be caused by an error in the admin configure.php file. I pasted this file beneath, can you help me?
Define the webserver and path parameters
// Main webserver: eg, http://localhost - should not be empty for productive servers
define('HTTP_SERVER', 'http://www.vanhooffmodelbouw.nl');
// Secure webserver: eg, https://localhost - should not be empty for productive servers
define('HTTPS_SERVER', 'https://www.vanhooffmodelbouw.nl');
// secure webserver for checkout procedure?
define('DIR_WS_CATALOG', '/winkel/');
define('DIR_WS_HTTPS_CATALOG', '/winkel/');
define('DIR_WS_BLOCKS', DIR_WS_INCLUDES . 'blocks/');
define('DIR_WS_PHPBB', '/');
define('DIR_FS_CATALOG', '/home/vanhooffmodelbouw.nl/www/winkel/');
define('DB_TYPE', 'mysql');
define('DB_PREFIX', '');
define('DB_SERVER', '10.0.0.3'); // eg, localhost - should not be empty
define('DB_SERVER_USERNAME', '2393zen');
define('DB_SERVER_PASSWORD', '****');
define('DB_DATABASE', '2393zen');
define('STORE_SESSIONS', 'db'); // leave empty '' for default handler or set to 'db'
define('DIR_FS_SQL_CACHE', '/home/vanhooffmodelbouw.nl/www/winkel/cache');
