Hmm, I must be mistaken then. Does Canada Post itself accept both units? If so, there should be an option to switch to/from metric from within the config.
No problem, if a customer purchases an item for $10.00 and shipping price of $5.00, the total to be processed by the payment processor would be $15.00. If the fee were 3%, this would equal $0.45 with $0.15 generated from the shipping charge. Now, let's say you charge a flat handling fee of $1.00 in order to cover the processing fees. If a customers shipping ends up being over $33.33, then you will take a loss on the additional processing fee which has now become higher than your flat rate handling fee.Can you please elaborate on what you mean by this statement?
On the other end of the spectrum, if you charge a $5.00 handling fee to cover higher shipping costs, when a customer purchases an item that should only cost $5.00 to ship and now has to pay $10.00, you may now lose the sale.
My updated version allows the user to use either/both the flat rate or the percentage handling fee.
Are you talking about the CanadaPost configurations or the ZC configurations? I myself have not seen it that Canada Post accepts both units; although, I haven't looked into it too much either. I thought that the module would convert it. I can't use kg for the the products because I have other shipping modules and they would not know that I have it set up to kg, at least I don't think so. What do you think?
God bless.
I have found that since my store is set to kg/cm by default, if I enter a product using lb/in, they will appear in kg/cm but with the exact same numerical digits as I had input for lb/in. So, I input all my products in kg/cm to avoid this issue. ZC itself should be converting units just as it does for currencies. Hopefully someone will fix this for you.
Actually, it's pretty simple to do, you can just do the conversions yourself within the script and when I get a chance I'll do the update to allow selection from the admin.
Apparently, Zen Cart doesn't actually store the weights in any unit. Instead, the number is sent to the module which then handles it using it's default measurement. So, if your store is in lb/in, you will need to divide the weight by approx 2.2 to get the kg and multiply by 2.5 to get the cm.
That is, I think, the problem, that ZC doesn't store the units in any format. So I could have a shipping module to think that the weight is in lbs and another that thinks that it is in kgs...
This should be added to the future wishlist. There should be at least a general configuration setting that sets what the general units are.
Kim, DrByte of Ajeh what do you think of this?
I've taken a closer look at the Canada Post module and it appears that if any products were entered using lbs/cm, it automatically converts them to kg before sending to Canada Post...
I'd recommend setting up a test website with an exact same product but with the opposite unit of measure and see if it returns different results. I'll upload version 1.3.7d sometime tomorrow. It can be downloaded from my website in the meantime.
Is it possible to have the module automatically use the user selected language to communicate with the canada post server? I.e customers who make their order using french language get responses in french from canadapost, those who use the english language get responses in english.
I'm going to have to create the language/french files for the module and I'll gladly provide them to whoever needs them.
