I'm designing my own website and I am very new to this. Can someone please help me set up my shopping cart? Please? Thank you and have a great day.
In the ZC download, there is a docs directory which will walk you through the setup.
Conversely, if you need someone to do it for you, you might try here:
http://www.zen-cart.com/forum/forumdisplay.php?f=137
BrandTim
There is a ton of information in the tutorials/FAQ section.
To create a very basic custom template (you can build from there), you need:
- includes/languages/YOUR_TEMPLATE/english.php
- includes/languages/english/YOUR_TEMPLATE/index.php
- includes/languages/english/YOUR_TEMPLATE/header.php (to change the logo)
- includes/templates/YOUR_TEMPLATE/template_info.php
- includes/templates/YOUR_TEMPLATE/common/tpl_header.php
- includes/templates/YOUR_TEMPLATE/common/tpl_footer.php
- includes/templates/YOUR_TEMPLATE/images/logo.gif
- includes/templates/YOUR_TEMPLATE/css/stylesheet.css
Anywhere you see a /classic/ folder, you can create a folder for your custom template. You can copy the necessary files from either the /classic/ folder, the /template_default/ folder or the parent folder.
Edit includes/templates/YOUR_TEMPLATE/template_info.php to give your template identifying information so you'll recognize it in the admin under tools->template selection.
Mary Ellen
I came; I saw; I Zenned
Taking over the world... one website at a time
Make sure brain is engaged before putting mouth in gear... or fingers to keyboard.
Holzheimer
Fan Odyssey
If you're having trouble with your ZC, you need to spend the money and invest in THE book:
http://www.zen-cart.com/index.php?main_page=page&id=16
It's very comprehensive.
Then, when you're comfortable with ZC as a whole, you can start the customization process and seek out other tutorials and information for that process.
HTH,
Lesli in SW Florida ~ writer, teacher, and dodging hurricanes!
I'm in the same boat. I downloaded a template and I can't figure out how to install it. I can get into the admin stuff, but I don't know how to get into anything else. Where do I find these files?
If you don't have ZC installed on your local computer, do so now. You don't have to be able to run it locally, but if you unzip it onto your local computer, you'll be able to see the directory/file structure and the directions will start to make sense.
In order to use the template on your website, you'll need an FTP client to do the uploading. FileZilla is a good free one.
Mary Ellen
Holzheimer
Fan Odyssey
Thanks for your reply. I have FTP access now, but I don't know where to put the template folder. I can't find anything in the directory that looks like a good place to put it. I found a folder called "www" and put it in there, but it won't recognize the template on the admin. Should there be a folder labeled "templates" or are there specific files I should replace?
The template files have to be installed in the same folders as the regular Zen Cart files. You shouldn't be REPLACING anything. You should be adding information.
Do you have Zen Cart installed on your website?
What template are you trying to install?
Mary Ellen
Holzheimer
Fan Odyssey
