Finally, I got it to work. I tested with my dummy data and it worked. I will not be able to answer questions as I do not code. The code to header_php.php is
(my last post with code had errors)
* header_php.php
*Zen Cart product filter module
*Johnny Ye, Oct 2007
* update by Jan Cabicar, Apr 2009
* update by Xzaqus, Sept 2010
require(DIR_WS_MODULES . zen_get_module_directory('require_languages.php'));
$error = false;
$missing_one_input = false;
if (isset($_GET['categories_id']) && !is_numeric($_GET['categories_id'])){
$error = true;
$messageStack->add_session('filter', ERROR_AT_LEAST_ONE_INPUT);
$categories_id ='';
$available = 'yes';
$option_ids = array();
$option_values = array();
foreach($_GET as $key => $value){
if(substr_count($key,'options')>0)
$option_ids[sizeof($option_ids)] = str_replace('options_','',$key);
$option_values[sizeof($option_values)] = $value;
if (isset($_GET['categories_id'])) {
$categories_id = $_GET['categories_id'];
if (isset($_GET['price_range'])) {
$price_range = $_GET['price_range'];
if (isset($_GET['available'])) {
$available = $_GET['available'];
if (isset($_GET['sort'])) {
$sort = $_GET['sort'];
$price_check_error = false;
if (zen_not_null($pfrom)) {
if (!settype($pfrom, 'float')) {
$error = true;
$price_check_error = true;
$messageStack->add_session('filter', ERROR_PRICE_FROM_MUST_BE_NUM);
$define_list = array('PRODUCT_LIST_MODEL' => PRODUCT_LIST_MODEL,
'PRODUCT_LIST_NAME' => PRODUCT_LIST_NAME,
'PRODUCT_LIST_MANUFACTURER' => PRODUCT_LIST_MANUFACTURER,
'PRODUCT_LIST_PRICE' => PRODUCT_LIST_PRICE,
'PRODUCT_LIST_QUANTITY' => PRODUCT_LIST_QUANTITY,
'PRODUCT_LIST_WEIGHT' => PRODUCT_LIST_WEIGHT,
'PRODUCT_LIST_IMAGE' => PRODUCT_LIST_IMAGE);
asort($define_list);
$column_list = array();
reset($define_list);
while (list($column, $value) = each($define_list)) {
if ($value) $column_list[] = $column;
$select_column_list = '';
for ($col=0, $n=sizeof($column_list); $col<$n; $col++) {
if (($column_list[$col] == 'PRODUCT_LIST_NAME') || ($column_list[$col] == 'PRODUCT_LIST_PRICE')) {
continue;
if (zen_not_null($select_column_list)) {
$select_column_list .= ', ';
switch ($column_list[$col]) {
case 'PRODUCT_LIST_MODEL':
$select_column_list .= 'p.products_model';
case 'PRODUCT_LIST_MANUFACTURER':
$select_column_list .= 'm.manufacturers_name';
case 'PRODUCT_LIST_QUANTITY':
$select_column_list .= 'p.products_quantity';
case 'PRODUCT_LIST_IMAGE':
$select_column_list .= 'p.products_image';
case 'PRODUCT_LIST_WEIGHT':
$select_column_list .= 'p.products_weight';
// always add quantity regardless of whether or not it is in the listing for add to cart buttons
if (PRODUCT_LIST_QUANTITY < 1) {
if (empty($select_column_list)) {
$select_column_list .= ' p.products_quantity ';
$select_column_list .= ', p.products_quantity ';
// Notifier Point
$select_str = "SELECT DISTINCT " . $select_column_list .
" m.manufacturers_id, p.products_id, pd.products_name, p.products_image, p.products_price, p.products_tax_class_id, p.products_price_sorter, p.products_qty_box_status ";
$from_str = " FROM " . TABLE_PRODUCTS ." p, " . TABLE_PRODUCTS_DESCRIPTION . " pd, " . TABLE_PRODUCTS_TO_CATEGORIES . " p2c, " . TABLE_PRODUCTS_ATTRIBUTES . " pa, " . znc_categories ." cat , " . TABLE_PRODUCTS_OPTIONS . " po , " . TABLE_PRODUCTS_OPTIONS_VALUES . " pov ";
$order_str='';
$listing_sql = $select_str . $from_str . $where_str . $order_str;
$listing_sql = "select DISTINCT ";
$listing_sql .= "p.products_id, pd.products_name, p.products_price, p.products_tax_class_id, p.products_image, p.products_price_sorter, p.products_qty_box_status ";
$where_str = " WHERE (p.products_status = 1 ";
$enable_attribute_filter = false ;
if(sizeof($option_ids)>0)
for($i=0;$i<sizeof($option_ids);$i++)
if(!(empty($option_values[$i])))
$where_str .= " AND ((pa.products_id In (SELECT pa.products_id FROM znc_products_attributes pa WHERE (";
$where_str .= " pa.options_id = ".$option_ids[$i];
$where_str .= " AND pa.options_values_id = ".$option_values[$i];
$where_str .= " )))) ";
$enable_attribute_filter = true;
if($enable_attribute_filter){
$where_str .= " AND p.products_id = pa.products_id ";
$enable_price_filter = true;
switch($price_range){
case 0:
$pfrom = MIN_PRICE;
$pto = MAX_PRICE;
case 1:
$pfrom = PRANGE1_MIN;
$pto = PRANGE1_MAX;
case 2:
$pfrom = PRANGE2_MIN;
$pto = PRANGE2_MAX;
case 3:
$pfrom = PRANGE3_MIN;
$pto = PRANGE3_MAX;
case 4:
$pfrom = PRANGE4_MIN;
$pto = PRANGE4_MAX;
case 5:
$pfrom = PRANGE5_MIN;
$pto = PRANGE5_MAX;
if(SHOW_SORT){
switch($sort){
case 0:
$order_str = " order by p.products_date_added DESC, p.products_date_available DESC, products_price ASC ";
case 1:
$order_str = " order by p.products_date_added ASC, p.products_date_available ASC, products_price ASC ";
case 2:
$order_str = " order by p.products_price ASC, p.products_date_added DESC, p.products_date_available DESC ";
case 3:
$order_str = " order by products_price DESC, p.products_date_added DESC, p.products_date_available DESC ";
if($categories_id !=''){
$where_str .=" AND ( p2c.categories_id = ".$categories_id;
$where_str .=" OR cat.parent_id = ".$categories_id;
$where_str .=" ) ";
if($enable_price_filter){
$where_str .= " AND p.products_price >= ".$pfrom;
$where_str .= " AND p.products_price <= ".$pto;
$enable_attribute_filter = true ;
if(sizeof($option_ids)>0){
for($i=0;$i<sizeof($option_ids);$i++){
$where_str .= " AND pa.options_id = ".$option_ids[$i];
if($available=='yes'){
$where_str .= " AND p.products_quantity > 0 ";
$where_str .=" AND p.products_id = pd.products_id";
$where_str .=" AND cat.categories_id = p2c.categories_id";
$where_str .=" AND p.products_id = p2c.products_id) ";
$listing_sql .= $from_str;
$listing_sql .= $where_str;
$listing_sql .= $order_str;
$listing_sql
//$breadcrumb->add('title');
// This should be last line of the script:
