Is it possible to not use a drop down menu but to just have text to select. For example When people click on any category
Has anyone got this working with 1.3.9? Whatever I choose it just brings back nothing, no results and no error .... www.Jambaroo.co.uk
I've obviously got attributes set, and have read through the forum as best you can when it gets to this kind of size...
Any ideas?
Has anyone tried XAttribSearch as a paid alternative?
Hi - i fixed my problem
1) when i uploaded I copied the files exactly was they were in the folder, this meant i ignored the Template_default folder presuming it contained the same content as the YOUR TEMPLATE folder... it didn't.
2) I still got an error stating it couldnt find the table zs_product_attributes. I don't have a prefix on my tables so went into the header file (includes/modules/pages/product filter results) and removed the zs_ from the below line.
$where_str .= " AND ((pa.products_id In (SELECT pa.products_id FROM zs_products_attributes pa WHERE (";
Now i just need to work out how to change the filter to £ from $...
Oh - and i'm no coder but i can't help thinking that someone who is could really contribute to the world if they could replace the drop downs with check boxes so a user can filter using multiple results?
Is it possible to not use a drop down menu but to just have text to select. For example when people click on any category if somebody could do that I can pay you $50
Example
Size (options name)
Small (option values)
Medium
Large
Color (option name)
Red (option values)
Blue
Black
Green
I've seen it asked a few times in this thread and am close to solving, just got one problem i cant get by, i am trying to make the dropdowns show in just categories, no problem have it set to show by $cPath, hve disabled catagories dropdown, and rewrote the where sql statement to
$where_str = " WHERE (p.master_categories_id = 22 "
works on category 22 fine
I also tried
$where_str = " WHERE (p.master_categories_id = '$cPath' "
and
$where_str = " WHERE (p.master_categories_id = '$_GET['$cPath']' "
also tried getting current path by
$my_dir=$_GET['$cPath'];
$where_str = " WHERE (p.master_categories_id = '$my_dir]' "
ive also tried a few other things in the header.php file and am getting nowhere trying to get current location inside the file i even tried globally with
{$_GET['$cPath'}
any help would be appreciated
I am not sure the whole SELECT you are using but if you are trying to use the current Categories ID ... you might try using:
$current_category_id
The master_categories_id will always be an immediate categories_id like 22 not a composit such as 10_22 ...
Thanks for the reply, i tried using $current_category_id and for some reason it always returns 0, i will keep trying to find a way to make it work and if i come up w/ somethin illpost it here
Ok so i think ive been trying to skin this cat the wrong way! seems if you set show catagories to false, it zeros out the current catagory.
i think to make this work id have to pull current catagory only into dropdown box and make it dissappear without actually setting to false??
anyone got ideas? thanx
mike
