I tried changing the case and got no rates at all. I'm guessing there is one more place to change in the file for zen-- this fix seems to work for the oscommerce crowd.
Tom
Tom
Should we also make a change in the bottom of the file? It seems like the configs should be in caps
Tom
$db->Execute("insert into " . TABLE_CONFIGURATION . " (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, set_function, date_added) values ('Domestic Shipping Methods', 'MODULE_SHIPPING_USPS_TYPES', 'Express, Priority, First Class, Parcel, Media, BPM, Library', 'Select the domestic services to be offered:', '6', '14', 'zen_cfg_select_multioption(array(\'Express\', \'Priority\', \'First Class\', \'Parcel\', \'Media\', \'BPM\', \'Library\'), ', now())");
Since this is a new problem and no one has heard from USPS; I'd be hesitant to change anything. I'd really like to know if this is a problem or a feature first.
I'm glad I'm not the only one with this problem!
We are working on a solution for the unannounced changes with USPS ...
We do not have confirmation yet as to the extent of these changes ...
I made changes in capitalization (array and config area) in my usps.php file and now usps works for domestic and international.
File attached
Tom
To make this work you need to uninstall usps shipping and then reinstall. After the reinstall, you'll see the shipping options in all caps where before it was not.
Tom
Update#3
The only rate I'm not getting is 1st class international. Otherwise all usps rates work.
Tom
Something changed at usps today and until the zen team gets a full fix here is mine. Domestic and international rates work correctly although no rates are returned for 1st class international
File attached.
Uninstall the old usps and reinstall this one.
Tom
Thanks!!!!
Its now working using your file.
