Right. That's what I meant.
I guess you could try re-uploading the mod folders/files and overwriting the ones that are there, in case one or more files are corrupted.
Thanks again,
I have actually tried that.
I know it works because when I switch to the classic template, it will work correctly.
It's when I'm using my custom template that I get the single column of death.
PROBLEM SOLVED....Mine is anyways.
I just installed the Column Divider Pro Module and followed the directions for use with the Layout Grid Mod. It overwrites the product_listing.php file that layout grid installs. Still not sure why this was happening but I am super happy now.
Here's the link to the download:
http://www.zen-cart.com/index.php?ma...roducts_id=945
Here's the support thread for this Mod:
http://www.zen-cart.com/forum/showthread.php?t=86483
I tried this solution, but still have the same problem. Product listing only shows 1 column. I'm also using a third-party template. Any suggestions..?
copy:
includes\templates\zcen\templates\tpl_modules_product_listing.php
includes\modules\zcen\product_listing.php
to your custom template corresponding folder.
I am having trouble with this one.
I have installed the mod and if I use the default 3 column set up, it works fine. When I set it to display by rows, it works as expected. What I want to do is display 2 columns - it wont do this but lists them in blocks in one vertical column. If I set it to 4 columns, it tries to do this but the 4th item spills over into the next row - probably because I have fixed width and there is not enough room for 4 columns (??).
Does this in Google and Firefox. Am using very slightly modified version of Classic template. Zencart 1.3.8a patched.
Mod should be installed correctly as it does work normally with the 3 columns.
Site not live.
Where should I look to fix this?
Leah
