the only one i find is this
htaccess_for_page_not_found_redirects.htaccess
If you are using windows on the local host, windows may hide that file. Make sure you tell windows to show all hidden files.
I no longer provide installation support on forum for all my modules. However, if there are real bugs with the modules please feel free to contact me
nope using Mac OSX
Make sure that you can view hidden files in your file viewerthe only one i find is this
if still not there get a new download and expand
What is your xampp apache errorlog telling you about the cause of the error?
did you find a solution?
I'm having the same problem.
i have the same problem, anyone can help ?
How about following all the suggestions posted above and post back here the result you get?
Try the following:
Open a Terminal window (Applications/Utilities/Terminal.app)
Inside the Terminal window, type the command:
Now your Finder windows will show all hidden files.Code:defaults write com.apple.finder AppleShowAllFiles TRUE killall Finder
MAKE SURE YOU DON'T DELETE ANY FILE YOU DON'T WANT GONE!
These "dot" files do exist in your MAMP folder.... as was suggested rename them from .htaccess to htaccess.txt
To turn this off, just use the command (within the Terminal.app)
MarkCode:defaults write com.apple.finder AppleShowAllFiles FALSE killall Finder
