Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Sep 2007
    Default Re: Admin Doesn't Work!!
    Quote Originally Posted by Kornizzkool View Post
    i'm not using an ftp, i'm running a localhost server to test the cart, i just copy my files into the server.
    htaccess is a hidden file that you need to see this to change the name
    Try the terminal and Use Unix command or log in as root
    my trick is I us Transmit for FTP and have it show hidden files on both local and remote folders
  2. #22
    Dec 2007
    UK
    Default Re: My Admin Doesn't Work!!
    Having bought the book I had several problems using XAMP running on OSX. This was extremely frustrating as I felt I was tantalizingly close getting it running on my laptop, which in my opionion is the only way you can develop a site without loosing your marbles.
    I solved it by installing something similar but specifically aimed at the OSX (MAC) environment called MAMP, which you should be able to Google very easily. I did this after unsuccessfully using XAMP, and prior to that, unsuccessfully using the APACHE server that comes bundled with OSX. I have been running a local Zen installation on two of my MAC's without any hickups since January. One is on 10.4 and the other is 10.5.
    Hope that helps, Zen is very MAC friendly once you know how
  3. #23
    Dec 2007
    UK
    Here's a link to MAMP provided from elsewhere in the forum
    Use one of the MAMP packages like the one HERE
  4. #24
    May 2008
    I just tried installing zen cart on my macbook (Leopard) and ran into the same internal server issue when accessing admin page, and my cart didn't have the right layout.
    It was fixed by the suggestions here.
    I ran the following script in a terminal (Applic########>Utility>Terminal)
    sudo su
    cd /Applications/xampp/xamppfiles/htdocs/zencart_138
    for i in `find . -name .ht*` ; do mv $i $i.donotuse ; done
    Good luck.
  5. #25
    Mar 2008
    Thanks to Kobra and Mewell and everyone else for suggestions here. I was having the exact same problem with same set-up- on my local Apache server on my Mac. I ran the command in a Terminal Mewell suggested a few pages back..
    Then I looked for and changed all .htaccess files to .htaccess.txt (both in admin and includes) in my zen files and voila! All fixed.
    Thanks so much!
  1. Fresh Install- Admin login doesn't work
    By ronlee67 in forum General Questions
    Last Post: 12 Jan 2016, 05:17 PM
  2. Rename admin doesn't work?
    By hamidz in forum Installing on a Linux/Unix Server
    Last Post: 28 Mar 2011, 03:34 AM
  3. SSL in ADMIN login doesn't work?
    By RAM1001 in forum General Questions
    Last Post: 11 Apr 2009, 06:23 PM
  4. Searching in Admin/categories doesn't work for me
    By panoptican in forum Bug Reports
    Last Post: 14 Jul 2008, 03:12 PM
  5. moved folders, now admin doesn't work
    By icklebits in forum General Questions
    Last Post: 27 Dec 2006, 06:47 PM
