OK thanks so much!
OK thanks so much!
OK sorry lol, but how do I set the boxes for the left and the right.
login as admin, then tools, then layout controller..how do I set the boxes for the left and the right
choose box you want to move...select left or right from options..
Thanks that worked perfectly! Now one more thing is there a way to make it show only 2 images in the new products on the left? It's showing 3 and that makes the columns uneven.
Girl you rock! That's perfect!
No problem.. my pleasure..great to see you are finally getting
your initial problems sorted.. You have some nice designs
there BTW
Thanks sweetie! I'm so excited lol!!
OK it's not working lol. I uploaded all the zip files into downloads but when I go to change the attributes where do I put the actual file at?
OK I found that lol. But do I need to change anything in the price and weights?
