Results 1 to 10 of 19
    Mar 2008
    application error There seems to be a problem connecting to our database
    [FONT="Arial Black"]I have had alot of issues with my website, now when i try to go to the store i get the error.
    Sorry!
    There seems to be a problem connecting to our database. Please give us a few minutes to remedy the problem. Thank you.
    Now i have read the forums and there may be a problem with my configure files. So i have pasted both files here. Can somebody please tell me if they see any issues with either one.[/FONT]
    [FONT="Arial Black"]admin/includes/configure.php[/FONT]
    // Main webserver: eg, http://localhost - should not be empty for productive servers
    // HTTP_CATALOG_SERVER is your Main webserver: eg, http://www.yourdomain.com
    // HTTPS_CATALOG_SERVER is your Secure webserver: eg, https://www.yourdomain.com
    define('HTTP_SERVER', 'http://leather2flesh.com.au');
    define('HTTPS_SERVER', 'https://leather2flesh.com.au');
    define('HTTP_CATALOG_SERVER', 'http://leather2flesh.com.au');
    define('HTTPS_CATALOG_SERVER', 'https://leather2flesh.com.au');
    define('DIR_WS_ADMIN', '/store/admin/');
    define('DIR_WS_CATALOG', '/store/');
    define('DIR_WS_HTTPS_ADMIN', '/store/admin/');
    define('DIR_WS_HTTPS_CATALOG', '/store/');
    define('DIR_FS_ADMIN', '/home/mistress/public_html/store/admin/');
    define('DIR_FS_CATALOG', '/home/mistress/public_html/store/');
    define('DB_TYPE', 'mysql');
    define('DB_PREFIX', 'zen_');
    define('DB_SERVER_USERNAME', 'mistress_zc1');
    define('DB_SERVER_PASSWORD', 'nRW71{2E19w{\[');
    define('DB_DATABASE', 'mistress_zc1');
    define('STORE_SESSIONS', 'db'); // use 'db' for best support, or '' for file-based storage
    define('DIR_FS_SQL_CACHE', '/home/mistress/public_html/store/cache');
    [FONT="Arial Black"]includes/configure.php[/FONT]
    define('DIR_WS_PHPBB', '/');
    [FONT="Arial Black"]Also when i try to log into my store admin i get the following error. Can someone please help me and save me. [/FONT]
    0 DB_ERROR_NOT_CONNECTED
    in:
    [db_cache table]
    Nov 2007
    Auckland, New Zealand
    Default Re: There seems to be a problem connecting to our database
    are you sure your password is correct.
    It is probably because you have not added yourself as a user to your database. Go to cPanel, then MySQL Database, and there should be a section which says "Add Users" where you can select your user name from a drop down list and then your databse from a dropdown list. Once you have assigned your username to your databse it should work. If it still does not work then try using a simpler password. Im not sure but the brackets and slashs could be confusing it. tell me if you succed.
    Oct 2006
    Alberta, Canada
    Not sure if this is a new problem or if you've had it since day one.
    First, I would change your db password:
    Get rid of the special characters for now.
    If you still get the error msg. "There seems to be a problem connecting to our database. Please give us a few minutes to remedy the problem.", then contact your Hoster. Problem could be on their end.
    Apr 2008
    Hi, Did you problem get resolved? I'm having the same problem, I cannot even access my www.domain.com/admin panel! Did you get yours fixed and if so, how?
    Jan 2008
    I am getting this same message:
    Sorry!
    Help!!
    Feb 2008
    Help!!
    My site has been up and running for months and has been fine, and then this morning the site is down with the message there seems to be a problem connecting to our database, and when I do to my admin I get the answer '0 DB_ERROR_NOT_CONNECTED
    in:
    [db_cache table]
    Help, help, what can I do to fix this!
    Sep 2008
    Yea, I need to second (third) this! I've been getting this on and off for a few weeks. I check the forums each time... I've triple checked my configure.php. My hosting provider is MediaTemple and I'm running an SQL container. Media temple is very reliable and since I'm seeing this same thing through out the forum it seems like it could easily be a ZEN cart thing.
    Today its only the ADMIN. And actually as I finish this post, it is now working. It only goes down for a bout 5 minutes at a time. We're not live yet, but it sure is tough when trying to show the client, but I get the following when working with the ADMIN:
    in:
    [select * from project_version WHERE project_version_key = 'Zen-Cart Database' ]
    Sep 2008
    OH... and this might be helpful: I'm using SSL and sometimes when I add the 's' to the http://...etc... the site comes back. But this is not always the case. Also, I thought when SSL is enabled the site runs exclusively on https// - for example the home logo points to http even thought I may be on an https page.
    Oct 2006
    Alberta, Canada
    SSL links are used when needed, not all the time. And the database problems are probably Hoster related. After all, if your site is working fine and you don't change anything but then start having problems database connecting, it only makes sense the problem is on the Hosting end.
    Sep 2008
    Thanks for the reply. I've got a support ticket out to my provider... I'll keep the thread up to date on what I find.
    Thing is... I keep seeing this problem pop up. The intermittent thing, I mean. What do you think could be the issue on the hosting end?
  1. v150 There seems to be a problem connecting to our database
    By rainbow_pixie_star in forum General Questions
    Last Post: 4 Mar 2016, 07:38 PM
  2. There seems to be a problem connecting to our database.
    By janelle in forum General Questions
    Last Post: 12 Sep 2012, 09:05 AM
  3. There seems to be a problem connecting to our database
    By carjamz in forum General Questions
    Last Post: 28 Feb 2009, 11:30 PM
  4. There seems to be a problem connecting to our database.
    By jenny_lisa1 in forum Basic Configuration
    Last Post: 14 Feb 2009, 02:51 PM
